Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1609 Questions View all
multiple issues (battery charge; headphone jack; loudspeaker) how to?
L.S.
I have been battling with my 6S since day one, now the situation is the following:
the load speaker is mute
the vibration doesn't work
the jack is mute
the battery doesn't charge
all of it unless i keep some pressure on the phone, as if there would be a loose connection in it.
I would love to open it up, but i would prefer to know upfront if i need parts.
As said, it all runs ONLY IF i keep it pressed.
Any advice aside the trash can?
Add a comment
1 Answer
Chosen Solution
I would suspect the charging port assembly may be at fault as it provides connections to all of those parts.
Note that it might just be the charging ribbon cable just needs to be replugged to logic board. Also check if the charging port assembly screws are all there.
Comments:
Ok, thank you, that makes sense.
I will take a look at it.
Cheers
M.
by
Add a comment
Add your answer
matteo malerba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 23
