Repair guides and support for the ZTE n817, also known as the ZTE Quest.
70 Questions View all
Power button is not jammed but can't turn on phone
The screen turns on when I charge the phone, but pressing the power button doesn't give any response. Before the battery ran out, when getting a text or call and the screen turns on, I can still use the phone even if the power button doesn't respond. But after it died and was recharged full, I need to use the power button to turn the phone on, which is impossible since it won't respond. How can I fix this?
Add a comment
1 Answer
Chosen Solution
Nevermind, I figured it out.
I took the back covering off and tried pressing the power button different ways. I'm not sure if that is bad but I figured out that pressing the bottom side of the power button without the back covering makes it respond. Pressing the whole button or the upper side with and without the back covering doesn't make it respond even if the button is not jammed.
Score 1
1 Comment:
I don't understand what you're saying exactly?
by
Add a comment
Add your answer
OctoberPie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 5,573
