Repair guides and disassembly information for phones from all manufacturers and service providers, including Apple iPhone and Samsung Galaxy. Get everything you need to repair your phone yourself.
73751 Questions View all
HTC Desier 816 : Not Turning on
this htc shut down suddenly and never turn on again , i 've searched for the service manual or datasheet or schematics but i didnt find anything , the battery seems dead the voltage drop on its pins is 0.8 volt when i put the charger it still 0.8 , removed the battery and measured the voltage drop between mobile battery socket pins while connecting the charger and the voltage drop was 0 , i tried to turn it on using my power supply when i press on power button it start consuming current 0.13 amp and keep like that if i let it connected to the power supply with no turning on , so i think the problem is on charging IC , what do you think , and what do you advice me to do
Add a comment
1 Answer
Chosen Solution
Try a different charging cable and ac block first just to be sure that isn't a problem. Then try replacing the battery if it seems to be dead. If that doesn't help, you might be looking at more of a component problem internally.
Add a comment
Add your answer
zain mobark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 11
All Time: 71
