Guides and support for various television (TV) brands and styles.
9051 Questions View all
panasonic c6 board location, not shown in service manual
panasonic p50v20a left side of screen 2 inches across and half way down loses colour or showing purple, can still see image behind.
fault seems permanent now.
my tv was fixed 3 times under ext warranty, always the exact same fault. 3 months out of warranty the exact same fault occurs again, miracuously fault dissapears on its own for at least 6 months until i connected a pc to tv then fault returned straight away, maybe it over scanned the tv as parts of desktop were not on screen.
people who fixed my tv each time told me the same panel was replaced each time and its panel C6 ( says alot when the part supposed to be brand new can only last 6 months ),
I found info about this board and bought one from someone who had dismantled my model tv. downloaded the service manual for said tv but i cant see any reference to a C6 board, i can c1,c2,c3. I have extensive knowledge of electronics and was going to replace the board myself but reluctant to take it apart when i cant find a diagram showing it. hoping someone might of replaced the same panel P50VT20 Plasma TV C6 Buffer TNPA5153
Add a comment
1 Answer
Chosen Solution
1. Remove the Hanger metal R. (See section 8.15.)
8.15. Remove the Hanger metals and the One leg bracket
1. Remove the Plasma panel section from the servicing stand and lay on a flat surface such as a table (covered by a soft cloth) with the Plasma panel surface facing downward.
2. Remove the One leg bracket fastening screws (×4 ) and the One leg bracket.
3. Remove the Hanger metals (L, R) fastening screws (×2each) and remove the Hanger metals (L, R).
8.16. Remove the Cabinet mount metals
1. Remove the One leg bracket. (See section 8.15.)
2. Remove the Cabinet mount metals fastening screws (×10 , ×20 ) and remove the Cabinet mount metal top and the Cabinet mount metal bottom
8.23. Remove the C6-Board
2. Remove the Cabinet mount metal top. (See section 8.16.)
3. Disconnect the flexible cables holder fastening screws(×10 ).
4. Disconnect the flexible cables (CA9, CA10, CA11, CA12,CA13, CA14 and CA15).
5. Disconnect the flexible cables (C61 and C66).
6. Remove the connector (C65).
7. Remove the screws (×4 ) and remove the C6-Board.
Score 1
2 Comments:
thanks , i actually found this same service manual and read all that after i had posted this question and it seems like you have to take the whole tv apart to get to c6 including the plasma panel and i can imagine one slip or mistake when the screen is no longer supported and then it all goes in the bin.
by
@jeffadelaide big job for a small board for sure.
by
Add a comment
Add your answer
jeff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
