Bissell's Bolt ION 2-in-1 Cordless for large rooms or smaller areas with detachable, handheld vacuum. Model number: 1312.
6 Questions View all
Why isn't my brush roll moving?
My brush roll won't move because there is something stuck.
Score 1
1 Comment
I have taken the brush assembly apart and cleaned any buildup which was minimal. It will spin sporatically. Most of the time not.
by
Add a comment
Most Helpful Answer
Open up your vacuum cleaner and check the belt. It likely has snapped or snagged and needs replacement.
Score 2
1 Comment:
ok, I ll try your recommendation, but still need the replacement that goes closer to the bus . The roller cover please. Would you help me?
by
Add a comment
the brush is ran by a belt. check to see if it has come off. you will have to remove the bottom but it is usually a phillips head screwdriver to do so.
Add a comment
Add your answer
jasmine soria-gamino will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 8
All Time: 380
