Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
No touch function after backlight repair (Advanced!)
Hi, this is my first question here.
I own a repair shop and do repairs on iPhone's for at last 3 years.
Now i got a iPhone 6s that drives me CRAZY!!!
A customer brought it in for a backlight damage, as always i checked the FL4211 for damage, none to bee seen also no burning, after i took of the CPU shield and the D4021 was a bit raised so i replaced it, after that the backlight came on and worked like a charm.
BUT, after the initial boot, the image on the screen was full of a pattern i have seen before, namely when you turn on a iPhone 6/6plus without the U2402 on. Vertical lines with some kind of checkered pattern.
I replaced 3 screens, cleaned the FPC, restored with latest os, nothing changed.
After i measured the "PP1V8_TOUCH_CONN" and here i found a open circuit, i made a strap on the "FL4209" and after that everything was in order with that line.
Still no touch function, i measured the following lines:
  • "SPI_AP_TO_TOUCH_CS_L";
  • "SPI_AP_TO_TOUCH_SCLK";
  • "SPI_AP_TO_TOUCH_MOSI";
  • "SPI_TOUCH_TO_AP_MISO";
  • "TOUCH_TO_AP_INT_L";
  • "AP_TO_TOUCH_CLK32K_RESET_L".
All of them give me a ~0.420V voltage drop to ground, no open circuit on any of them!
Also i mesured the "PP5V1_TOUCH_VDDH" when the phone was on and i got the 5.1V on that line.
I cannot understand what the problem is? Where am i missing something? There is no mechanical damage to the board, all SMD parts are in the right places.
Maybe someone has a ideea...
Thanks in advance.
D.
Add a comment
Chosen Solution
Have you checked the Chestnut circuit? Beyond the 5V1 line, there is also the PP5V7_MESON_AVDDH
& PN5V7_LCM_MESON_AVDDN. There is also the PP1V8_TOUCH (Fl4209) line which also powers the touch functionality.
I would also check the AP_TO_TOUCH_RESET_L line (FL4134). Then there is the LCM_TO_OWL_BSYNC line (FL4230). There are lot's of Touch lines on page 42 of the schematic.
Score 2
Add a comment
Hi,
I have done some iPhone board work but I still don't know much but I know what if you search up STS telecom on Youtube he does lots of these problems. It's worth having a look.
Hope that helped
1 Comment:
Thank you but still did not find a solution to my problem...
by
Add a comment
in my case i checked SPI_TOUCH_TO_AP_MISO and no value checked on another working board and there is a testpoint next to the cpu i could run a jumper from but my bord dont have value on the testpoint either so the last point is inside CPU so am stuck at this point
1 Comment:
In my case in diode mode I get 0.001v = short to ground? I would reball CPU but it feels the CPU is shorted internally?
by
Add a comment
Add your answer
Dacian Bujor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,363
