My epson stylus R240 printer is showing some error.
Hi,
My epson r240 is showing some error on its screen as shown in the picture. If someone might be able to guide me as to what to do, please?
Thanks in advance.
Hi,
Thanks in advance.
At some point you have directed it to print from an sd card and its informing you theres no sd card in the machine and you need to insert it . you need to go into your settings and close this process . If you cant find the proper route to go back then simply shut the machine off and unplug for a minute to clear the printer cache , then clear your que in the printer properties on your computer. Hope this helps
Thanks for the reply I’ll try & see if it works. When I send the print from the computer, it says printed successfully within seconds but actually nothing gets printed.
@fluffysoft check to see where your directing you print . it may be looking to not pint a physical print but to print to documents or a storage device. make sure your destination is set as the printer and not Microsoft document or other
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 338
