My phone fell down and now the screen is dark I can't see anything or
My phone fell down and now the screen is dark I can't see or type anything, what do I do?
Gloria ,check your battery by removing the back cover. Remove the battery from the phone , inspect it for damage such as swelling leaking or other obvious signs of damage . If all is well reinstall it try powering on the phone and listen for the startup chimes and the vibration that usually accompanies the start up. If all this is good and you hear it staring up then the problem is with the LCD it will need to be replaced . You can purchase new screens and on ebay or amazon or here from ifixit
This video will guide you through the process
https://www.youtube.com/watch?v=ef2Oahpa...
If you dont get the startup chimes or any indication its starting up there is more serious damage done. If this is the case then contact use again and we can help from there. It is most likely the LCD will need to be replaced. Hope this helps
سلام صفحه نمایش گوشیهای لمسی جدید بسیار به ضربه حساس میباشند وتصویر انها از بین میرود شما حتا اگر کسی به تلفن شما زنگ بزند تلفن شما زنگ میخورد اما تصویر ندارد شکستگیهای خیلی کوچک درصفحه نمایش تلفن به وجود ماید که با چشم به سختی قابل مشاهده است وتنها راه حل این مشکل سپردن تلفن به تعمیرگاهای مجاز برای عوض کردن صفحه نمایش تلفن میباشد سوال دیگری داشتید با من تماس بگیریدamirslamefar@gmail.com
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,770
1 Comment
Hi i have this problome to with my phone . You should try looking at the battery of the phone to see if ther is damge on it
by Ross Clark
