Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
iPhone won't restore when plugged into iTunes
The phone all the sudden stopped working so I decided to restore it. When I hold the power and home button the display is blank but iTunes says its in recovery mode. I downloaded the ipsw and started the restore, I saw an apple logo and the loading bar under it but even after leaving it all night the bar made 0% progress. can anyone help??
Add a comment
1 Answer
Most Helpful Answer
If you saw a blank screen after pressing those buttons but iTunes said you were in recovery mode, you successfully entered DFU mode.
It sounds like iTunes is giving you grief so, try using 3utools to flash instead of iTunes.
Score 1
2 Comments:
Thanks, I used the tool but it said "invalid serial number" do you know how to fix that?
by
Try
a) Taking out the SIM Card
b) use DFU mode (I assume you are already doing so)
c) If this is PC, check device manager to see if there are any errors around your iPhone listed.
If these don't resolve your issue, you may have hardware damage around the charge/data port.
by
Add a comment
Add your answer
Maxton Fanberg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 274
