The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
100 Questions View all
pls help me how to fix it.
My Samsung j200 has sundenlly drop and sink in the water and the I turn on in 3days before that happen but when I turn on it was white screen in the LCD and all are fuctioning.... The sound the notification and even a screen shot have heard function so what should I do to fix this pls help me..
Add a comment
Chosen Solution
You need to first get it completely dried up or get it checked cause there could be some moisture etc and could damage electronics in the phone if you continue to use it , the problem with the White screen could be the digitizer failure.
Score 1
2 Comments:
Tnx I appreciated your comment.
by
The didgitizer is what senses your touch. It would not affect your display.
by
Add a comment
Completely cover the phone in a covered container of rice for a couple days to remove all moisture. I have read this on other sites it may or may not work due to how long the phone has had moisture.
1 Comment:
Rice is actually bad for your phone. If you just want it to dry, let it sit for a long period of time. The only problem with drying it, is it will start corroding. WATER+AIR=CORROSION. Corrosion will eat away at the phone continuously.
by
Add a comment
Add your answer
nickroms ferrer will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 9
All Time: 169
