Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
Changed screen now battery won't stay charged
Got in iphone 6 plus, screen is smashed, changed the screen out and moved over the home button. Comes on, display works properly, Touch works, home button works. It will show 100 percent charged then go to 1 percent and shut down. Try to turn back on and it goes to the screen with the battery with a red line. Plug it in let it sit for a minute phone comes back on, and it shows that its charging. Battery life shows 97 percent. If i disconnect it and use the phone in only a few minutes it will go to 1 percent and shut down again. I got a new battery on the way. Anything else it could be?
Add a comment
1 Answer
Chosen Solution
I would guess battery. Probably damaged when the display was damaged. Should be the answer to your problem. If it's not, sounds like charging circuit. Let's hope not, those are not simple repairs
Score 3
1 Comment:
Yep i would conclude tristar too.
by
Add a comment
Add your answer
mikebarkas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 53
