What's the best way to install cooling fans
What's the best way to install cooling fans on a 1998 dodge stratus?
@buckhunter53 here is how they get installed. So in your case you will have to start at the end of this:
Replacement
Note: When reinstalling the fan assembly, make sure the rubber air shields around the assembly are still in place - without them, the cooling system may not work efficiently.
Thanks oldturkey03!! I was just curious if it was easier to disassemble with the radiator attached as one unit because of the lack of room? I really appreciate your input on this!
@buckhunter53 either way it looks to be a pita. I think for as long as you have the upper radiator hose removed, you should have enough room to shimmy by.
I have another issue with this car , although it's related. It has bad cooling temp sensor and it was preventing the fans from coming on and the motor overhead and shut off. Now I unhooked it now the motor is running rough. Can it be because that sensor is not hooked up or is it another major issue? I really appreciate your input on this!! Thanks!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 47
1 Comment
@buckhunter53 are you inquiring about replacing the stock fans?
by oldturkey03
