Repair guides and support for cars and trucks by Ford Motor Company.
1398 Questions View all
"Door open" warning from sliding door
Hi,
I am driving a Ford Transit from 2008 and I keep getting a door open signal from the sliding door when I drive over bumpers or around curves even though the door is closed.
When I lock the doors with the light on it closes, but the lights stay on and the horn goes off. What could that be?
Greetings,
Christian
3 Comments
I Have a Ford Tranzit F250. , 2015 ! The slide door get closed and locked , but it shows as alert that the door is opened ! Turns the light on and makes that sound ! It hapens more after a rain ! If anyone can help plz
by
We have a fleet of '13 and '15 T250s . 11 of our 45 vans do this. We have replaced the hinges as the doors appear to be slightly open and also the door sensors to no avail. We are in Michigan so the bumps are constant. The ding and flash the dome light all day and night.
by
Noalox on the connections. It is conductive. The issue with mine was the contacts weren't touching properly. This more or less solve the problem every once in awhile it will give me a side door alert but it's rare now.
by
Add a comment
Chosen Solution
Hi @destard
Sounds like you have a faulty pinswitch in the door frame or the wire connected to it is shorting out to the chassis. The switch is manually released and operated by the door opening and closing
Not sure with your model but think that it is located on the right hand side of the door opening.
Sometimes the switch gets corroded and goes s/c (short circuit). Switch should be s/c (in released position)when door open and o/c (open circuit when switch pushed in) when the door is closed
You need to remove the switch from the chassis and test it with an Ohmmeter to prove that it is working correctly.
If the switch is OK then perhaps the wire connected to it is earthed somewhere. The insulation could be rubbed or the wire could be pinched and it is shorting out to the chassis.
Score 3
Add a comment
There’s a few things to check before blaming the pinswitch. I thought it was my pinswitch as well when it would bing every time I hit a bump and then eventually just stayed on. However, I had someone push the button in while I was in the drivers seat and verified that it worked correctly each time the pinswitch was pushed manually. That led me to realize it was a door alignment issue on the sliding door that was preventing it from fully shutting. There are several videos on youtube, but the general idea is that on the hinge on the back top that suspends the door there is a bolt. Turning it towards the vehicle raises the door, and lowers the opposite direction. Raise the door until the trim panels line up and you can visibly see the latch hitting the striker dead center. Then lower the locking nut to keep it from backing back down. Now your door should shut all the way and the alarm will quit driving you nuts. You will also likely notice that the door no longer squeaks like it has a family of chipmunks living in it when going over bumps.
Score 1
Add a comment
Add your answer
Christian Hackbarth will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 58
Past 30 Days: 220
All Time: 26,110
