Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2266 Questions View all
Why my iPhone won't boot?
my iphone 7 fell into the toilet and doesn't work anymore.
iphone boot up but it stuck on apple logo .
if i try to connect iphone to the computer in every ways, recovery mode, dfu mode, normally, computer doesn't recognize it.
please help me
thanks
Add a comment
1 Answer
Chosen Solution
Your phone was either damaged from falling on the hard porcelain or from getting infiltrated by water, possibly a bit of both. Even though the iPhone 7 is water resistant, it is still possible some water got inside. At this point the phone must be opened and cleaned properly asap.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
If the phone still doesn't work, then a micro-soldering repair shop can properly troubleshoot your phone.
Score 1
Add a comment
Add your answer
Emanuele Amantia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 82
