Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3670 Questions View all
Can't turn on my MacBook Air Early 2015
So my MacBook Air was working normally till yesterday. It was laying on my table and as I wasn't using it it went to sleep mode. At one point I heard a start-up sound but I ignored it.
Later when I tried to use it again and turn it on nothing happened. I could only hear fans inside working loudly. Now sometimes I hear them, sometimes nothing happens at all.
I tried resetting SMC and NVRAM but it didn't work.
Does anyone have experience with similar problems or any idea for what I should try next?
Add a comment
1 Answer
Most Helpful Answer
It sounds like your system was in the process of an OS update. Restart your system make sure you have a wired connection to the internet (not WiFi) as well as connected to a MagSafe adapter (powered). Then let it be for about a hour or two, it should restart again on its own once the systems firmware has been updated which is what I suspect was taking place when you stopped it.
If that didn't work see if you can put the system in Safe mode when you restart it.
Score 1
Add a comment
Add your answer
Antonio Buničić will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 78
