Why is it that the screen is not coming.
Please my laptop screen is not showing up
The power comes alright and the light of the power is on as well but the machine isn't start up from the screen.
I've cleaned up the memory and inserted yet no sign of coming,the fan too is running. Is AMD 6A
Please help me
Add a comment
1 Answer
Chosen Solution
Hi,
Connect an external monitor to the laptop and see if there is a display showing on it.
If there is also no display on the external monitor then there is a problem with the GPU (or the CPU as often the GPU is integrated with the CPU) or the motherboard.
If there is a display showing on the external monitor then there could be a problem with either the video cable between the LCD display and the motherboard, the video cable connections (at either end - motherboard or LCD display), the lid switch or the LCD panel itself.
With the laptop turned on, shine a torch at an angle, close to the screen and see if you can detect an image on the screen at all.
If there is a display (and it will be very faint) then you have a backlight problem. Try it in a darkened room. This can be caused by either a faulty backlight power supply, a faulty backlight cable between the motherboard and the LCD display (it may be part of the video cable -not sure about this for your model), a faulty lid switch or a faulty LCD panel.
Hopefully this is of some help.
Score 2
Add a comment
Add your answer
achestylish will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
