Powers on but doesn't flash
I recently bought a yongnuo 560 iii flash. The screen powers up fine, the flash charges and shows a ready light but when I press the pilot button or shutter button it doesn't flash at all, though it does make a sound like it should have.
Please advise a fix and how to complete it. Thanks!
Ps I've read it may be a capacitor problem but I know nothing about electronics.
Add a comment
1 Answer
hi,
'''Quick Fix!
Be sure to follow all of these steps without skipping anything in order to fix your issue. If you're only trying to fire the flash attached to the camera, you'll only need steps 1-3 below. If you're going to use the flash off-camera with a YN-560TX controller, then follow all of the steps on this page in order.
Step 1: Make Sure the Flash Itself Is Working and Has Power
With the flash turned off, press and hold the “on/off” button on your flash for a few seconds until it turns on. Press the “pilot” button. If the flash pops, then chances are good that there is nothing wrong with the flash and that we simply need to work on getting the right settings.
If the flash does not pop, put in brand new batteries (try not using rechargeables) and try again. If it still does not work, then the flash is defective. There is no setting that would prevent the pilot button from firing the flash.
Step 2: Factory Reset Your YN-560
To reset your YN-560, hold the audio and mode buttons (“C” and “D” in the diagram above). This is how you access settings. Now that you're in settings, press the up arrow key (“G” on diagram) until you see “CL EA.” Now hold the okay button and you'll see chasing squares at the bottom right. Once that gets done, it's reset.
Step 3: Make Sure the Camera and Flash Can Communicate
Attach the flash to the hotshoe of the camera. Be sure to push it TIGHT all the way forward and lock it down by spinning the plastic circle on the flash above the shoe. If it doesn't seat all the way forward, it won't fire. Turn on the flash and take a picture. If the flash fired, then move on to step 3.
Next, press button “E” (shown on the diagram above) on your flash until the flash looks exactly like the picture immediately above this section. This changes the receiver mode so the flash will accept the “fire now” signal from the hot shoe of a camera. On the back LCD of the YN-560, you should see a little flash symbol at the very top-left, and an “M” on the right side of it. Don't worry if the other numbers on the flash are different, but there shouldn't be any additional numbers showing anywhere on the flash.
Quick Fix!
The most likely issue that prevents the flash from firing is if your CAMERA is in live view mode, on continuous low or continuous high drive mode. Be sure you're using the viewfinder and that when you press the shutter button down and hold it, only one picture is taken.
Set your camera in single shot drive mode. This should mean that when you press your shutter button and hold it down, only one picture is taken. Many cameras will NOT fire a flash if it's in continuous high or continuous low mode. Be sure to check this. Turn on the flash and take a picture. If the flash fired, then move on to step 3.
If the flash hasn't fired yet, don't worry. We have some other things to check. Make sure you are using the viewfinder. Many cameras will not fire a flash when in live view mode. If the rear LCD is showing the picture before you take it, then you're in live view. Switch to viewfinder only. Turn on the flash and take a picture. If the flash fired, move on to step 3.
Rarely, but sometimes, a camera will not fire a flash if in continuous focus (written as “AF-C” on Nikon cameras or “AI-Servo” on Canon cameras). Change your focus mode to single shot focus. Take a picture. If the flash fired, move on to step 3.
Now, set your camera to manual exposure with a shutter speed of 1/100. Take a picture. If the flash fired, move on to step 3.
Next, be sure that your camera is not set on quiet shutter or “silent mode” as it is sometimes called. Also, check to make sure you're using mechanical shutter and not electronic shutter, which is a feature of most mirrorless cameras. You'll know you're using mechanical shutter if you hear a significant “click” sound when you take a picture.
The last thing to check for is to make sure you don't have a setting turned on that suppresses flash. Many cameras have a setting that suppresses flash so that if you're at an event where no flash is allowed, you can ensure that no flash will fire.
If the flash did not fire after following all of these steps, then something indeed could be wrong with the flash, or you could have purchased the wrong flash for your camera model. If you have a friend with a DSLR, try it on theirs. If it still doesn't work, then the flash could be defective and should be returned. At this point, we've gone through all of the possibilities that could be tripping it up.
Step 4: Make Sure the Controller and the Flash Can Communicate
Now we're going to take the flash off camera. Things are going to get a little more complicated, but fear not! I'll walk you step-by-step through this issue.
First thing we need to do is set up the flash to accept a signal from the YN560TX wireless trigger. To do that, press button “E” (on the diagram at the top) until you see a symbol of a flash with the tiny letters “RX” under it. This is wireless receive mode. BE CAREFUL NOT TO CHOOSE “TX!” I know it seems like you'd want TX since that's the name of the transmitter, but “TX” means you want to put the flash on the camera and use the flash itself as the trigger. Choose “RX.”
Next, we're going to check the channel and group of the flash. You can customize this later, but for now I want to make sure it's on channel 1, group A. This does not get set back to default when you reset the flash. You'll have to set this up.
To change the channel on the YN-560, simply press the center “okay” button on the 4-way selector (“G” on the diagram at the top of this article) and then press the up and down keys to get to the channel you want, then press the center button again.
To change the group on the YN-560, press buttons “E” and “F” (as listed at the diagram at the top of this page) at the same time. Then use the up and down keys to cycle through, and press the center okay button (part of “G”) to accept. You should now be on channel 1, group A.
Now set down the flash. It's set to go, and should look like the picture in this section. It's time to set up the YN-560TX controller.
The good news is that this part is super simple. Just hold the “Zoom/Ch” and “Mode” buttons at the same time for a few seconds to reset the YN560TX trigger. This will zero out all of your settings and put it in channel 1. That's all you'll need to do.
At this point, your YN-560 TX trigger and your YN-560 flash should be able to communicate with each other. Turn on both units. Press and HOLD the “Test” button on your YN560TX trigger. It should make the flash on your YN560 fire the flash.
good luck
Add a comment
Add your answer
Caitlin Boberg will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 43
All Time: 2,491
