Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
855 Questions View all
Engine starting, but will not forward or reverse.
Hi all -
Toro Timecutter MX 5050 zero-turn lawnmower
My new lawnmower abruptly stopped today. The engine kicks on just fine, but engaging the steering handles are non-responsive. My first thought was that I ran over something that jammed a gear or something. I don't know enough about zero-turns to diagnose. Any thoughts on what I should check first?
Thanks
Score 1
1 Comment
This ... We just bought ours today used it to cut around the house then had to stop for a second then nothing. Would not go forward or reverse?? Cranks fine, cutter works fine ???? Help
by
Add a comment
1 Answer
Chosen Solution
@kadekaaz the very first thing I'd check is the drive belt make sure that it is routed properly and see if that works.
Check your clutch to make sure it works.
After that check to see if the control arm is properly seated on your hydrostatic drive as well as the motion control assembly.
Toro list these as possible causes for your mower not moving:
1. The bypass valves are open.
2. The traction belts are worn, loose, or broken.
3. The traction belts are off of the pulleys.
4. The transmission has failed. (unlikely;-)
Score 3
Add a comment
Add your answer
Kade Kaaz will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 186
Past 30 Days: 770
All Time: 30,891
