Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
Siri can't hear me nor does voice dictation work
My microphone works for phone calls and for recording, but Siri can't hear me (total flat line) nor can I dictate into any app. I've checked all the settings. Rebooted, etc. all the usual things. However, Siri and voice dictation work fine through my headphone jack, just not through the microphone. Is this a hardware problem?
1 Comment
I should add that I just swapped in a different logic board. Could I have missed a connection?
by
Add a comment
Chosen Solution
There are 3 microphones in the iPhone.
https://support.apple.com/en-us/HT203792
  • The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
  • The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
  • The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation
I would test the microphones with the appropriate apps to determine if the problem is specific to a microphone (change the appropriate flex) or multiple microphones which could indicate a logic board problem.
Score 5
2 Comments:
I have the same problem. How do I check the mics?
by
How do I check the mics please.. what app
by
Add a comment
use a toothbrush, and lightly brush the mic holes and you'll see that the rainbow wave animation moves for both top and bottom mics. Siri has stopped on two iphone X's after jailbreaking. Also a samsung watch wont connect either but it will after a clean reset.
Score 1
Add a comment
Same issue here microphone working fine on other apps not problem, Siri works with side bar and hears me fine. Only issue I can activate “hey Siri” feature. Was working before update 14.2 on iPhone XR
Score 1
1 Comment:
Did you find a fix?? I have the same problem.
by
Add a comment
Add your answer
Rick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 26,107
