My touch screen is not working properly.
I am not sure what's going on here. My Touch screen just not working properly. I tried replace 2 new screens but still not working.
Is it intermittently not working at all, ghost touching or dead spots?
If it's intermittently not working at all in most cases the touch ic chip needs to be replaced by someone that does micro soldering.
Ghost touching and dead spots are caused by bad screens.
Yes. I think maybe the chip is not working. I tried 2 new screens both working at first, and then no touchscreen response after an hour or two.
Harry Chow , have you checked the connector on the motherboard ? Clean it with alcohol to have a try.
Thank you very much for your reply. I did check the connector everything is fine. After I replace the screen actually worked for a little while, and after an hour when I waked up the screen the touchscreen suddenly not working at all. I think might be mother board broken.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,797
