Find solutions to your computer repair questions.
21215 Questions View all
Windows factory reset stuck on 43%
I have opened up an phishing email and downloaded a virus. I realised the second i done it it was a mistake so I disconnected everything. Long story short my pc was infected so I have set it back to factory reset and wiped the hole lot. Everything was going fine until the resetting got to 43% and now it has been stuck for hours.
Any ideas?
Thanks.
Score 1
1 Comment
what is PC manufacturer ? What windows are you trying to install?
by
Add a comment
Most Helpful Answer
Same thing happened to me.
Just don't panic and keep waiting.
It will teleport to %99 after waiting a few hours.
Score 2
1 Comment:
I am currently experiencing this myself so this was helpful to me. I read elsewhere that as long as the drive light is blinking it is continuing to work on the reset. So trying to be patient!
by
Add a comment
Sorry for your trouble and this has happened to many when rolling Windows back to factory.
It would be good to know your manufacturer and operating system, but lets look at this from the standpoint all computers all operating systems have this problem some times,
Because you have wiped your hard drive, we will go past saving your data and let you know in the newer computers there is a hidden partition on the hard drive that contains the original operating system including the drivers for your systems devices. You can get to this partition by usually pressing the F8 key as you do a reboot from power off, it brings up a screen with options to reset, run in safe mode, check memory and others depending on the manufacturer. So the computer is locked up, well do not worry just give it a try from the start again using the F8 key method. I do not want to confuse you so I must say not all computers use the F8 key but could use F10. Go to the manufacturer web site and get the manual for your computer and read up on it. You can also just do a Google search as I am sure many people have had to find out what keys to press to get to your repair screen. If all else fails then borrow a disk with the same operating system (home premium, Pro has to be the same) and reinstall from scratch, using the product key that should be stuck on your case. If there are some drivers not installed Windows will know and do upgrades (several times).
All this typing and actually I know little if what you have tried, but don't be discouraged. You may have it all work in reinstalling just by pulling the power cord and doing a reboot for Windows to get past what ever it hated and you are golden.
Good luck
Alton
Add a comment
First thing you wanna try if u been waiting for hours remove all the memory except one stcik
Try the recovery then.
Add a comment
Same happens to me, but I used Windows 10 install disk to reset my laptop to factory default.
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 15,551
