The phone won't charge after battery overheating
the phone has stalled during use and the battery has overheated, when the charger is plugged in i get the message: battery alert... the battery temperature is abnormal,charging has been stopped.
Score 2
4 Comments
@rosioaratudor Have you tried turning off your phone for a few hours until the battery is cool, and then turning it back on? and doing what you just did before?
by
Battery paused exceeded ideal temperature range
by
Yes it has refused to turn on completely
by
I have tried all the above questions
by
Add a comment
Most Helpful Answer
Try leaving the device off for a day or so.
If it does not work:
Consider getting it repaired for a battery replacement. Remember to not play with it on for too long, turn it off if not playing and do not overcharge it.
Score 2
Add a comment
Over heating won't charge
Add a comment
I found a 1.1kohm dead rezistor on pcb near the battery connector ,i replaced and work fine.
Add a comment
I have not found the right help for my phone
Add a comment
Add your answer
Tudor Rosioara will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 3,481
