My sanyo dt46840 has been cutting on & off just fine
my sanyo model dt46840 has been working just fine until now it cut off and noe want cut back on not even the green power light
@walters1995 on a completely dead set you want to test the power supply first. Of course make sure that your outlet has power and that your power cord works. After that you need to take the back of your set off and check the power supply fuses for power and continuity and see if you get power to the board. It is best if your post plenty of images of your boards with your question so we can see what you see. for that use this guide Adding images to an existing question
You will need some basic tools and a decent multimeter to check on this.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 30
