Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
I got the white screen of dead, Touch is working
Hello,
i've got an iPhone 3GS and replaced the display, because it was broken. Because i didn't use the iPhone for a while i updated the Software to the current iOs-Version. The problem i've got now, is that when i click the Home Button or the PowerButton to switch on the Display i just get a white screen. If i restart/reset the iPhone the screen is working fine. When i have the white screen i "can use the screen blind" if you understand. For example, i'll can switch on the iPod, i can unlock my phone and i can switch it off. Everything with the white screen.
What do you think? Is this an Software error or an hardware error? Any solutions for this? What could be the next steps to fix it?
[sorry for my eventually bad english]
Score -1
Add a comment
Chosen Solution
Turn phone off and recheck all your connectors 1-3. More than likely is no. 1! Then close it up and make sure no 1 is staying on.... It's a tricky little connector and pops off as you close. Then I'd do a reset- press and hold power and home until apple appears- let it reboot.( While you have it open give connectors a quick clean)
Score 2
1 Comment:
Well i tried this more than one time and it doesn't change anything. If i restart or reset my iphone i get the normal screen e v e r y t i m e. I just get this white screen wenn my iphone is switched on and i click the home or power putton to "light up" my display.
by
Add a comment
Upload all of your info onto iTunes. Then get all of the latest updates for the iPhones downloaded onto your phone. Then reload all of your info. It worked for me yesterday! BTW, I did this with the help of Apple iPhone Repair - over the telephone - 1-800-694-7466
Add a comment
Add your answer
Max will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,532
