Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
99 Questions View all
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
Score 2
7 Comments
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
by
Different battery perhaps?
by
Do I have to try with a different battery? Can it be a motherboard's problem ?
by
Yeah, it could be either the mother board or the battery.
by
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Asus ZenFone 2 Battery Image
Guide
Asus ZenFone 2 Battery Replacement
Difficulty:
Difficult
20 minutes
Asus ZenFone 2 Motherboard Image
Guide
Asus ZenFone 2 Motherboard Replacement
Difficulty:
Moderate
15 minutes
Score 2
1 Comment:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
by
Add a comment
Add your answer
Vincenzo Liguori will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 375
