Plugged in wrong voltage charger, now won't turn on
After pluging in wrong voltage changer my tom tom won't power up
Tried reset button, over night change .
will it need new battery or is there a fuse inside ?
Hi!
You could try to remove the battery and put it back in. If the device works then, you're good.
Otherwise you will have to replace the motherboard because the fuse went off (most likely).
Thanks will try that
Tried this but battery biult in can't be removed .so thinking bin it
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 180
