Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
After Battery Replacement, My iPhone 6 Keeps Rebooting.
I accidentally mixed up the screws that secure the charging cover. I put them back in the right place, but now my phone reboots after about 3 min. Is there anything I can do?
Score 1
Add a comment
Chosen Solution
Turns out that the pins on the cable weren’t ligned up right.  They were just a little bit off, and that’s what was causing the issue.  We got them aligned right and everything worked.
Add a comment
Before you mixed up the screws, the iPhone booted properly and worked for more than 3 minutes?
2 Comments:
Yes, before the repair it worked normally. I also noticed, it doesn't reboot while in Airplane mode for some reason.
by
The behavior of rebooting every 3 minutes is very odd. I dont believe (could be wrong) that mixing up those screws can do damage. If memory serves me right, the screws pass through the board and not directly onto where a longer screw would do damage.
by
Add a comment
Before the repair, you mean with the original battery? My guess: the replacement battery is a bad one. Try another battery please.
1 Comment:
I put my origional battery back into my iPhone and even did a software restore, and it still reboots.
by
Add a comment
This looks to be a general problem on iPhones whenever thys battery replacement..I’m facing the same challenge. my 6s+ keeps restarting over and over and charge percentage is stuck after replacing the battery… gosh! quite irritating
Add a comment
Add your answer
Alex Hadfield will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 15
All Time: 2,112
