Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Replacement battery won't charge
Successful replaced my iPhone 6 battery but it won't charge past 1%
Any ideas
Add a comment
Chosen Solution
It is possible that your replacement battery is defective. It also sounds like the problem was more with the charging circuit than the battery.
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
I would try a known-good battery to eliminate that possibility. Otherwise, you will need to have your phone looked at by a micro-soldering repair shop.
Score 1
Add a comment
What was the point to change your battery? Are your phone wont charge or you had battery drain?
Add a comment
Did it charge before you changed it ?, if it did you have a bad battery. If not you more thank likely have bad tristar and / or active diode.
1 Comment:
If your previous battery did not charge at all you should check the charger. Check the voltage across the terminals with a DC voltmeter. If it has some value close or higher than nominal battery voltage the new battery most likely has a problem.
by
Add a comment
Add your answer
kelly webster will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 128
