Timothy Dumlao do you hate your iPhone? If you don't, why did you use rice? Take it out of the rice. IT DOES NOT WORK This is a myth that really has to disappear. Skip the rice. It is absolutely useless.''' It will not help you fix your phone. All it does is that it provides a false sense of security. It will not clean your phone, it will not prevent corrosion.
Second, stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
5 Comments
Did it turn on? Did you get a new Battry?
by Taylor
I found my iPhone emerged in water, and immediately took it out of the water. But since I was in school, I couldn't put it in a bag of rice. I left my phone in a dry area and came back to get it, and found that it wouldn't turn on, the screen is completely black. I don't know what to do, any suggestions?
by Margaret Weld
Same situation,...Deja Vu
by akua_asa
Rice is the absolute WORST thing to do when a phone gets wet! Here is my expert advice - fixed hundreds of liquid damaged phones - what to do when your phone gets wet:
Actual experts in the tech repair industry, who have worked on liquid damaged iPhone's since they were invented continue to urge people to follow a few simple, but important steps if your phone gets wet:
1) Take it out of the liquid immediately!
2) Turn it off and DO NOT CHARGE IT!
3) DO NOT Shake it, bake it, blow-dry it or put it in rice!
4) TAKE IT to a local professional tech repair shop ASAP!
Rice will NOT dry the phone out completely and drying it out is only the first issue. Cleaning out the corrosion is what will cause additional issues - like the screen going black. A local repair shop MIGHT be able to still save your phone. Checkout my blog for more help: http://wigoman.blogspot.com/2019/05/welc...
by Rob Link
My iPhone dropped in the toilet for about 2 seconds and i put it in rice and left it over night and now it won't turn on screen is black what should I do?
by Laverne Thomas
