Mac HD crash - Need to backup files & reinstall OS
Hi Guys,
My iMac HD crashed and I'm unable to boot into my Mavericks OS. From the Recovery partition, I used the Disk Utility feature, but in vain. It's unable to repair the HD. I have also not taken any backup of recent files, nor have I used the Time Machine either. I tried using an old Ubuntu startup disc and was able to access the other files in the HD, apart from the root user files. However, my important files are the root user files. Also, I'm unable to use my Mac keyboard with Ubuntu and that makes matters worse. Moreover, the system now seems to assume the default startup disc as the CD source itself, and states that the boot device is missing if I don't insert a CD. Hence, I'm unable to use Recovery partition or Disk Utility unlike earlier. I need to be able to change the default startup disc. Also, should I maintain a bootable Mavericks OS installer from a USB and re-install the OS on another partition? Then I can take a backup of the required files from the main HD and then proceed to re-format and system and re-install the OS.
I have earlier undergone a similar issue and was able to succesfully backup the files & reinstall the OS. I just can't seem to remember what I did previously. There's no physical problem with my HD.
Please help.
