The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22 Questions View all
Why is powershell (the main operator of Windows) not working properly
After some time I use my computer then I get this message: powershell stopped working. I don't close it because I don't want to find out what happens. I also removed all the viruses in my computer
1 Comment
Person -- What version of Windows are you running? Powershell is just a feature of Windows, not the "main operator."
by
Add a comment
1 Answer
Chosen Solution
You can shut your laptop and restart it. Power Shell is similar to the command prompt but more capable. If you continue to get the message that Power Shell is not working then you can open a command prompt (with admin) and type the following SFC /scannow, this will check and repair system files. If this doesn't work then try using Windows Restore to reload the operating system. Be sure to back up your data files before doing a Restore.
Score 1
2 Comments:
Thank you, the scan found a corrupted file and now i dont have the problem anymore
by
oh wait, now ive got two, didnt help, neither step 3
by
Add a comment
Add your answer
person will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 646
