Computer not turning on, (Fans go full speed, Lights 1 2 blink)
I recently took my computer apart for cleaning, when I turned it on the fans went full speed, diagnostic lights 1 2 start blinking, and nothing comes on screen. Help?
Score 3
4 Comments
You've made sure that all cables are connected correctly? None have been damaged while it was apart?
by
I did a quick check to make sure, bit later on, when I have time, I will reseat the CPU and see if that fixes it. If it doesn't than I'll let you know!
by
@vinylcake what does the power button look like while LED 1 and LED 2 blink? Is it off or is it amber?
by
Add a comment
1 Answer
Chosen Solution
@vinylcake from the service manual for your computer:
LED 1 and LED 2 Blinking Power Button Amber
Problem Description A possible system board failure has occurred.
Troubleshooting Steps
• Disconnect all internal and external peripherals, and re-start the computer. If the computer boots, add the
peripheral cards back one by one until you find the bad one.
• If the problem persists, the system board is faulty.
LED 1 and LED 2 Blinking Power Button OFF
You do want to make sure that you properly inserted all your cards and that everything is connected. Since you did not tell us to what extend you cleaned your computer and exactly what you did, it will be difficult to pinpoint this.
Score 1
1 Comment:
i have changed the system board but again its not starts . its shows the orange little for 1 second and again turned off.
by
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 83
All Time: 16,857
