Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4600 Questions View all
iPhone 6 won't stop vibrating when alarm goes off and charging
Hi,
Hoping someone can offer some advice here as read a ton of forum posts where the issues are slightly different and not been able to find a response yet.
Phone has had a cracked screen for a while and had 0 issues with it, phone working perfectly. Last week with my phone plugged in on charge, my alarm goes off as normal, but this time the screen freezes completely and the phone stays on a constant vibrate.
Only way to stop this is to force restart the phone, and when I do this the mic stops working on the phone till I reset it again.
It is worth noting that the screen is lifting up a bit from the bottom right corner of the phone.
Can all the above symptons be linked to the cracked screen or does it sound more like multiple issues going on.
Thanks in advance for your help!
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
You should definitely consider changing the screen because you will have to open this phone up anyway to inspect what is going on inside. Not having seen your phone, many cracked screens start having glass chips and dust that can fall out or in some cases fall inside the phone. The vibrator is a mechanical device so that may cause some issues. I don't really see a link with the microphone though.
However, because the screen is cracked, it seems fair to assume that the phone has suffered some drops and under certain circumstances cause logic board issues. So open it up and take a look around and report back with your findings.
Score 2
Add a comment
Add your answer
Chris Thompson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 337
