Apple released the MacBook Pro 15" Unibody, the second generation of the MacBook Pro, in October 2008 with a new aluminum upper case machined from a single aluminum block.
3092 Questions View all
Why won't my battery charge?
I recently replaced my battery in a MacBook pro 15" 2011 model. I did so using ifixit instructions and battery. After 3-4 charge cycles, the battery will no longer charge. The macbook says battery not charging and the magsafe cable never turns amber. I have tried everything online such as unplugging power adapter and resetting the smc. What are the odds I have a bad battery?
Score 1
2 Comments
I think you have a faulty battery, Everything was working until now. See if you can get a refund. What brand was this battery?
by
Are you able to send a picture of your charging panel? You might have to get a new charging panel or charger.
by
Add a comment
1 Answer
Most Helpful Answer
Have you tired reseting the SMC
Plug the MacBook in and hold
Shift+Control+Opinion+Power
This may help
Score 1
2 Comments:
Yes I tried that. I also unplugged the battery from the control board for a few seconds.
by
Maybe the battery is defective
by
Add a comment
Add your answer
Jacob Hopkins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 103
