Repair guides and support for your Samsung TV.
Check Fan #1 Model HL67A750A1FXZA RE01
I am receiving the check fan #1 message when I turn on our Samsung 67" DLP television. I know that there are 3 fans inside and I've replaced the larger fan already but I can't figure out which fan is fan #1 and what the right part number is. Every fan I've ordered ends up being the same size as the bigger fan and I'm pretty sure I need the smaller one.
Score 1
Add a comment
1 Answer
Chosen Solution
@chs00802 your set use 3 fans. One large one and to small ones. If unsure, use the image from the service manual to verify the fan. Following the wiring from the control board to the fan.
Since we do not know which part number you replaced, check on that for us. It should be BP31-00032. The smaller ones are BP31-00025B which some manuals list as no longer available. BP31-00025B still shows as available at places like this. A substitute for that is BP31-00029A.
Score 3
3 Comments:
@oldturkey03 the fan I replaced is BP31-00032A. I will order BP31-00025B or BP31-00029A, thank you so much for the information.
by
@chs00802 you are welcome and best of luck to you. BTW welcome to iFixit ;-)
by
where do you find the service manuals - I have a LA46A950D1FXXY which says Check Fan 1 so was going to take it in to get replaced, but I reckon I can do it myself. Anyone know where I can find the service manual for my unit. Looks like this is a regular occurance with Samsung TV's.
by
Add a comment
Add your answer
Carolyn Szymanski will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 4,519
