The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 Questions View all
Phone Won't Turn on
I just replaced my digitizer and now the phone will not start. It shows an orange led in the speaker when charging but that's the only sign of life it has. Is there a connector I could've missed? Any ideas?
Score 1
Add a comment
1 Answer
Chosen Solution
The screen itself uses a single LCD ribbon cable where the digitizer is together plugged into.**
Double check if the LCD ribbon flex cable is plugged in fully.
Score 3
2 Comments:
Only one cable connects to the motherboard correct? The second cable is already attached to the "main" cable that you plug into the motherboard. The "main" cable is fully plugged in.
by
You are right. I haven't done a HTC One M9 screen replacement in a long time. I have like 3 screens sitting in the stock.
Orange LED indicator means the phone can most likely switch on after it has sufficient charge.
Have you tried holding power button until it vibrates when on the orange charging led?
You should be able to hear sound from it when it boots up (unless you put the phone in silent mode).
by
Add a comment
Add your answer
Logan Green will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 688
