Repair guides for the KitchenAid KHB100OB Immersion Hand Blender.
3 Questions View all
How to replace the motor (or perhaps just the fuse)?
My immersion blender shorted out. There was a flash of light inside the housing and now it will not work. Any ideas for how to replace the fuse, or perhaps the whole motor?
Score 3
1 Comment
How to replace the fuse
by
Add a comment
1 Answer
Most Helpful Answer
Our KitchenAid model 5KHB100 started smoking while using it. Looked up instructions on disassembly and could find none.
I took this one apart, it is not screwed and clips holding the case together, it is glued and not easy to take apart without damaging it a bit. Not made to be dismantled and repaired.
I have a couple of photos of the inside.
Time to go source a replacement.
Score 2
2 Comments:
Hey Garry, any tips for unsealing the glue? Did you just use a heat gun?
by
Hey Mike, I didn't but could have helped if I had used one. Just pried it apart hoping there were clips to make reassembly easier.
by
Add a comment
Add your answer
Becky Piscitelli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 1,762
