The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Questions View all
My phone won't turn on
My phone was low battery (20%) before I went into work so I plugged into a fully charged portable battery, turned the phone off, and went into work. After 7 hours I came back to my car and tried to turn on my phone. Instead of turning on it flashed a red light once (same LED as "the phone is dying" light) for about two seconds. I've had it unplugged from the charger, my phone felt cold so I assumed it might be too low of a temperature or something and it's been over an hour of the same response whenever I try to power up.
Did my portable battery fry the phone's battery or something? It hasn't happened before, I've done this many times while leaving the phone on and charging with no problems.
Score 1
Add a comment
Chosen Solution
Keep it plugged into a wall charger, hold power and volume down for 15 seconds then try holding power button for around 5 to 10 seconds to try turning it on.
Hopefully you get a battery logo sign meaning it is beginning to charge the phone.
Score 2
1 Comment:
My boyfriend has plugged it in to try if that would work. Few minutes later the battery symbol appeared. It's weird how the phone still managed to die but it's fixed now!
by
Add a comment
Worked a treat thank you
Add a comment
Add your answer
cassidy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 37
All Time: 6,114
