What's causing these verticle lines?
Samsung UE48JU6445 4k TV
I have faint lines that appear when there is text, menus or straight lines in the image.
Any ideas what's causing the issue and if it's repairable?
Here is a photo of the issue of that helps
Score
0
@harrythick seems to have trouble with viewing your images. You can add images to your question right on here by following his guide Adding images to an existing question
The issue with the lines could be a bad panel, bad TAB or bad T-con board. We do need to see a bit more of what you are seeing.
by oldturkey03
