Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
457 Questions View all
3DS will not turn on, fuses OK, battery seems OK, ... HELP!
Hello smart people -
My son's 3DS fails to turn on.
Battery tests OK (4+ volts)
When charger plugged in battery charges for a while then stops.
When battery pulled out charge light only stays on for a few seconds then goes out.
Completely disassembled unit to check the fuses on the main board and they test OK.
I'm stumped.
Anyone have suggestions? Thanks.
Add a comment
1 Answer
Maybe you need a new battery? It sounds like its fried. You should be able to get one off eBay or amazon!
1 Comment:
Hi Rose - thanks for the suggestion. I just tried a new battery on Friday and no luck. It isn't the battery.
I just ordered a used mainboard off eBay... hopefully that fixes it! :)
by
Add a comment
Add your answer
Greg C will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 79
