Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
intermittent charging , fake charging , fluctuating battery percentage
Hi , i did a water damage repair of the backlight ic on this 6s which went well phone is working again ,, but i didnt realise it was fake charging , i have tried a new battery and , dock , still the same , i have changed tristar chip , still the same , i just got a usb amp meter and it showed around 1 amp current draw for around a minute then dropped to 0 the battery percent did rise from 65% to 68 % then jumped to 75% so seems a bit all over the place ,
i have tested P_IN on tristar it is 5v and PP1v8_SDRAM it is 1.8v
im not sure where to go next ,
Add a comment
1 Answer
Chosen Solution
What about PP3V0_TRISTAR; what voltage are you measuring?
Have you checked R2400 which is inline on TIGRIS_TO_BATTERY_SWI? On the older models there used to be a filter. If it is dislodged or damaged, you will have this kind of erratic charging.
Does iTunes properly recognize the phone and have you tried to do a backup/sync to see if the communications work fully? Remember that Tristar is above all else a communications chip, not a charging IC. The real charging is driven by TIGRIS (via the SWI line) which is itself controlled by the CPU.
I would also test the TIGRIS circuit completely if the above hasn't solved your problem.
Score 2
3 Comments:
Hi , sorry so long to reply to this , I started to test the components around the TIGRIS chip , but just at a critical stage my 4 year old came running over for " daddy cuddle" pushed me and the tip of the test probe destroyed one side of the tigris chip !!! . i was less than amused as you can imagine ,,
i ordered a new tigris and while fitting it my air station did not seem hot enough so i turned it up , then up again , then all of a sudden a great amount of heat and several components were blown out of place , Q2300 disappeared and the audio ic 's solder balls came out from beneath , the tigris aswell ..
At this point i was nearly ready to give up but decided to get a new hot air station (quick 861) what a night and day difference ,, i reballed the audio ic , tigris and replaced the Q2300 , blew all the moved components more or less back were they belong ..
I could not believe it when the phone not only booted up but all worked fine !!
The charging issue must have been the Tigris chip all along ..
Sorry for the long post and i really appreciate the help ..
best regards .
Mark..
by
Yeah, but 4 year olds are adorable...I'm sure you forgave him/her quickly :>).
I have heard great things about the Quick 861. I have a Hakko myself so I'm set but it's good to hear that you are satisfied.
Congrats on a great repair!
by
Thanks , and yes he was forgiven fairly soon ..
by
Add a comment
Add your answer
markparnell1972 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,917
