Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Replace iPhone 3G 8GB Board with 16 GB other one.
Hi,
I am trying to replace logic board in iPhone 3g 8GB capacity with other on, 16 GB, the 8GB board give the error 28 . 16 GB Board (from ebay) doesn't power up. Are the boards compatible to each other, or there is the problem with connector?
Or 16 GB Bord is dead?
Thanks a lot for you help.
Score -1
Add a comment
Chosen Solution
the parts for connections for 8gb and 16gb, as long as they are both 3g, are compatible.
if you are finding that the phone won't power up after a logic board switch you'll need to check
1. recognised by itunes
2.vibrate toggle on/off works
if these work then it is either a display issue in which case you need to check connector 1
3. if nothing happens then you'll need to check connector from headphone jack, connector 4 (the dock) are on properly and the battery connections/pins aren't flattened etc.
get back to us if this doesn't work.
I'm assuming that you bought the 16gb as a working logicboard, if this is the case then you can always try getting a refund.
Score 1
Add a comment
Hi,
thanks for your replay.
no iTunes reaction, no windows. all cable checked. I thought, the board isn't compatible, but now i am sure, the board is damaged.
I will contact the reseller.
Thanks again for your help
cu Etienne
Add a comment
Add your answer
Etienne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,743
