Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone has vertical black lines why won't it update/restore?
Hey all!!!
The iPhone won't update. It won't progress past the point shown in iTunes/the phone in the pictures attached.
I have tried updating with the screen off, with a different original screen, a new battery inserted.
It did at one point restore, but then it turned off and started boot looping with vertical lines showing up on the screen.
Any help appreciated!
Add a comment
Chosen Solution
What happened between the phone working well and the failed update? Is the phone still boot-looping?
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Get back to me with your observations by commenting on this answer.
Score 1
Add a comment
i am also having this problem..were you able to find a solution??
Add a comment
Add your answer
kenn millard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 654
