Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
Replaced & installed old battery/ Screen flickering
I have an ipod video 5th generation that I've had for about 4 years. Just recently, the ipod stopped working and would not turn on at all. After plugging it in to a wall charger it would not charge, let alone turn on. Then I tried connecting it via USB to my macbook pro and still nothing. I ordered and installed a new battery. When I tried to turn it on the Apple simple came on then it switched off a few seconds later. I then plugged it into my macbook pro and the display on the ipod said "very low battery, connecting" After it sat for a while I unplugged it to see if it was charged and attempted to turn it on. Upon trying to turn it on, the screen began flickering white light and has been doing so ever since. I've done everything to try to get it to boot up but nothing has worked. The flickering white light only stops when I unplug the battery. Any suggestions??
Add a comment
1 Answer
Chosen Solution
detwilerzam64, open your ipod up again and check the connector for the battery. I've had a few where the connector was loose on the board, yet not all the solderpad were of and some still made a connection. You could also check the LCD connector under your hard drive to see if it is on right. Good Luck
Score 1
Add a comment
Add your answer
detwilerzam64 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,478
