Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Questions View all
Screen doesn't have a any output after replacement
Hi guys
I recently changed the screen on my iPhone 6s since it had cracked, but it doesn't seem to have anything come up on the screen. The phone is still working. iTunes still picks it up and everything. It's not recovery mode or anything, just no picture.
Any help would be much appreciated
Add a comment
1 Answer
are you sure that you insert lcd flexible correctly? i have also experienced same prob and fix it by replace mainboard
11 Comments:
Yes I believe that I have done everything correctly. I followed the steps on this site
by
you sure lcd module is not broken or defect? or try with other lcd if not show up you should reball the chipset, if you don't have experience at reballing with hot air you can try using hair dryer
by
How do I reball the chipset? I tried with another screen and I have the same problem, but it works on another phone that i have
by
Sounds like a faulty screen or blown backlight filter.
It's almost certainly a faulty screen if the old screen was working and just cracked and still works when you plug that one back in for testing.
I assume you unplug the battery first before unplugging / plugging in other cables?
by
I used the new screen on a different iphone and it seemed to work fine
by
Show 6 more comments
Add a comment
Add your answer
Shranal Kumar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 67
