Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Bluetooth is very weak and cuts out after disassembly, what's wrong?
After a screen replacement on an iPhone 4 32GB I reinstalled IAW the guide here on ifixit. The problem/question is, everything works great, but once stereo bluetooth comes on I can only get 10 to 15 feel away without it cutting out, also if the phone is in my pocket it will cut out. I went through the phone again, cleaned all contacts with 99.9% pure Iso alc wearing latex gloves and only made a slight improvment, all internal parts are in great shape with no damage other than the back cover was exposed to a heat gun tring to remove the back glass. What is the next step in fixing the bluetooth? Is the bluetooth using the back cover attenna?
Add a comment
1 Answer
Chosen Solution
This pressure contact touches a small area on the backplate of the phone which is part of a separate antenna array. Check out this forum and look at the posting from JoshHawn http://forums.macrumors.com/showthread.p... and the antenna itself is discussed here http://robertthorpeconsulting.com/wordpr... good reading. I do think that they use the back plate pressure contacts to connect. So make sure that they make contact. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Joseph Razmek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,787
