iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Why wont iPod connect to computer?
So getting the sad face :( ,but i cant even connect it to computer to try the restore option, tried different usb ports, to no avail. tried manual reset, just get website addy again. when i connect i do get apple then the sad face and if i look in right light i can see that it says "please wait.. very low battery and can see the little dots turning, but ipod is not charging. Any ideas on how to fix??
Score -1
Add a comment
1 Answer
Chosen Solution
kevin, in most cases this has been a hardware issue, but try this first. try to p put your iPod into Disk Mode by
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button. More on this on here http://support.apple.com/kb/HT1339
If you cannot force your iPod into disk mode and restore it, i would think you are looking toward a new battery and/or a HDD. If the battery won't charge, nothing will work properly. It's also a cheaper fix. Which version iPod do you have? Here is some more info. http://www.best-ipod-online.com/ipod-dis... ..good luck and let us know what works for you.
Score 1
2 Comments:
I have the ipod classic, i tried to get to manual disk mode to no avail, just brings me back to sad face. I figured i would be looking at one of those 2(battery or hard drive) but figured i would verify before i started dumping parts/money into it. thanks for your help, will respond when i get parts replaced as to what it was.
by
kevin, start with the battery. It's cheaper and may just resolve the issue. Let us know how it is going and good luck
by
Add a comment
Add your answer
kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 881
