The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1538 Questions View all
Why isn't my phone turning on after being in rice over night
Hi last night I dropped my phone down the toilet I picked it up straight away wiped it with a towel and put it into a bowl of rice I've left it there all night tried turning it on this morning and it was just a black screen I tried plugging my charger in and my phone was making a weird noise.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Because rice does not help. If you want the device to not die from liquid damage you need to open it up as soon as possible, unplug the battery and brush the liquid off using 90%+ isopropyl alcohol on the connectors and any corroded / burnt looking areas.
Then dipping the logic board in isopropyl alcohol helps a lot in displacing water under the metal shields and small chips.
Lastly you need to dry out the alcohol from the board using air / heat or just letting it sit for a while (still i would use heat / blown air) to dry it out. Then hope for the best and that it still boots up. You may need to replace the screen, it sounds like it also got faulty from liquid damage.
I'll wait for someone to post a liquid damage guide.
Score 2
Add a comment
My hubby fell in the creek with his phone in his pocket. I immediately took the back off and removed the battery and dried what i could. When we got home i put all the pieces in a tupperware bowl with the anti-moisture packets you get in things like new shoes. Left it overnite, put it all back together works great no damage I can find.
Add a comment
Add your answer
Mik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
