Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
black screen but with apple logo , no backlight
Hello
when i turn it on , i can barely see the apple logo from the black screen but after it goes i can't see anything
also there is no backlight , i tried to turn on the phone in the dark , couldn't see the apple logo till i turned on the light and looked closely
tried to change the screen , but gives the same problem
also i tried to remove the battery and turn it on with power supply , still the same problem
is it the screen IC , or what else should i check ?
thanks
Add a comment
1 Answer
Chosen Solution
Have you confirmed the phone actually boots up by checking USB Connection through iTunes or 3UTools?
If the phone is detected in recovery mode then it isn't a no backlight issue.
Score 2
4 Comments:
yes it does appear in itunes
but i can't access it since it require to confirm from the iphone that i should allow access from pc , but i can't press anything in the iphone because i have black screen
by
It's probably the backlight filter shorted / blown. You will need to get it replaced if that is the case. You can do it yourself if you can do micro soldering otherwise take it to someone that does iPhone board repairs.
by
ok , but how can i do backup for now ?
by
I suppose you could use a lightning to hdmi adapter to see the display on screen then use the screen's touch screen to navigate with the phone to unlock, trust computer and do an iTunes backup.
Otherwise try using it with dim display / no backlight and backup to iTunes.
by
Add a comment
Add your answer
Hesham Adwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,327
