How do you set it back to factory settings
This is a new machine
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi! I have copied this answer from another LG washing machine post I located on iFixit @ LG WASHER won't drain or spin
"To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a “reset” signal to all the components. (This is a common fix that many appliance repair mechanics use – it works on about 50% of all washing machines.) "
I was hoping that my google skills could help you find a solution and from my research this is the best one I could find! I hope it helps.
Score 2
3 Comments:
Thank you...it worked!!!
by
Thank you!!!
by
Thank you it worked for my machine! Ayeni Samuel kelsinki from Nigeria
by
Add a comment
Add your answer
joken1962 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 12,550
